How do I add a global variable to my schematic?
infinite.machinery
infinite.machinery
As the topic says. I want to add a global variables named DRAWING_NAME. How is that done?
jorge_garcia
Hi @infinite.machinery,
I hope you're doing well. The dialog for this functionality has not come into Fusion 360 yet. In the meantime, I'm pretty sure the command line syntax will still work.
ATTRIBUTE * nameofattribute 'valueofattribute'
The * is very important that's what makes the attribute global.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
jonas.juden
This won't work if I try to use ATTRIBUTE * nameofattribute 'valueofattribute' in library device. It will say that invalid character in attribute name referencing * character.
In schematic sheet it won't give any error but there is no way of accessing that attribute if that was even created.
panpan_fan
I hope you are doing well!
We support Document Attribute in Fusion 360 V2.0.13615.
Please have a try to see if it works well for you.
Panpan Fan
