Using import-bmp ULP
infinite.machinery
infinite.machinery
I have created a black and white logo bitmap with the correct color mode. When I run the import-bmp.ulp script it get to the end where it is going to place the logo on layer 200. I press OK and create the script, which I run, but nothing is showing up on layer 200.
Does this ULP work in Fusion 360?
jorge_garcia
Hi @infinite.machinery,
I hope you're doing well. I just tried it and it worked fine.
Check near the 0,0 location and make sure that you scaled the image so that it's visible. It's probably the case that it's there but it's too small to see.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
infinite.machinery
I looked at 0,0 and there was nothing there. I think the problem was that I was selecting colors from the color map that did not exist in the bmp file. I made sure I only selected one color that did exist in the bmp file and now I'm seeing the image.
