Footprint pad array 4 sides
duncanBC5DV
duncanBC5DV
Is it possible to create a pad array with 4 sides
When I select either SMD or PTH pad array tools, it starts with left and right selected, top and bottom are grayed out. If I deselect left and right, I can select top or bottom, but then left and right are greyed out. Am I missing something?
jorge_garcia
Hi @duncanBC5DV,
I hope you're doing well. It sounds like you want to use all 4 sides. Currently the array commands don't support 4 sided footprints.
I'll make a ticket for this so that this can be improved. For now if you need a 4 sided footprint you can run the current array functions twice. You are not missing anything.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
duncanBC5DV
Thanks for the prompt reply @jorge_garcia
I must say I'm still a little bit concerned as to how this feature was released without supporting 4 sides, it brings the validation testing into question, perhaps you can pass that on to your colleagues.
duncanBC5DV
Any movement on this issue @jorge_garcia ? It's been 8 months. I tried to run the 2-sided pin array twice and got some very strange results:
