- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The package generator is a godsend for the times I have to use it and I am generating a standard chip size and footprint. However, there are times when a specific stop layer has been defined on the datasheet and I have had to go back and manually edit the dimensions of tstop and tcream.
Would it be possible to implement a basic feature to adjust the clearance of the tstop and probably the tcream layer whilst making a package. When working with a 144 pin package and the clearance of the tstop layer is 0.07mm instead of 0.1mm, that would be a godsend.
