Feature request: more options in package generator
robert.martinUKYP4
robert.martinUKYP4
The package generator is a godsend for the times I have to use it and I am generating a standard chip size and footprint. However, there are times when a specific stop layer has been defined on the datasheet and I have had to go back and manually edit the dimensions of tstop and tcream.
Would it be possible to implement a basic feature to adjust the clearance of the tstop and probably the tcream layer whilst making a package. When working with a 144 pin package and the clearance of the tstop layer is 0.07mm instead of 0.1mm, that would be a godsend.
jorge_garcia
Hi @robert.martinUKYP4 ,
I hope you're doing well. Thank you for the suggestion, I'll pass it along to the team.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
benjamin.jordan
Hi @robert.martinUKYP4 yes there are ongoing frequent updates to the Package Generator. This is very helpful to hear form you. Some of the recent updates make it easier to customize a footprint in ways like this.
So just to be clear on this page you'd like to also see an override for solder and paste mask openings, right?:
Ben Jordan
Senior Product Manager, Fusion 360 Electronics
LinkedIn | YouTube | Personal Blog | Fusion 360 Electronics Series
robert.martinUKYP4
Hi Ben,
An override for solder paste and mask would be ideal
