Bug with component rotation
silvio3105
silvio3105
there's a bug with rotating component in 2D PCB.
Look at designator. After first rotate, I did CTRL + Z and tried again.
Thanks!
https://youtu.be/WsGhKotcZjY
silvio3105
Bump!
yiqiu.han
Hi, @silvio3105
You mean the rotation angle of silkscreen "R1" is not correct at first, right? Could you please share your board file with us for investigation?
-Yiqiu
silvio3105
Yes.
Can you try with generic component? I had same issue with both THT and SMT component.
On first try, designator angle will be some garbage, then Ctrl+Z and reenter component's value and then it will work.
It does not look like file/project related problem.
silvio3105
Little bump
