[BUG] Using Reposition Attributes on a Module will cause Fusion to crash
anranlioculus
anranlioculus
The first problem is that the value of the name attribute doesn't update automatically for copied module instances. For example, the copied A1 module has the name A2, but the name attribute still carries the A1 name.
The workaround is to rename A2 to something else and then back to A2.
Then there is no way to restore a deleted module attribute. Using the reposition attributes function on a module will cause Fusion to crash.
  • bug
jorge_garcia
Hello @anranlioculus ,
This is unexpected, i'll share this with the developers.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Closed-Loop-Bot
Thanks for bringing this to our attention. We're investigating the issue, and you can reference ticket FUS-272006 when communicating with Autodesk to find out more. Once the status of this will change, there will be a follow-up forum post made.
anranlioculus
Hi Joege, could you look into another module related bug? This one is a lot more critical, it will cause file corruption.
https://forums.autodesk.com/t5/fusion-electronics-forum/bug-the-board-file-has-errors-and-cannot-be-...
jorge_garcia
I hope you're doing well. I've passed both issues to our QA team for investigation. IF you have a file you can share that just makes things easier for our developers.
Best Regards,
​Jorge Garcia
