[BUG] The board file has errors and cannot be saved
anranlioculus
anranlioculus
Inserting an electronics design that contains a module into another electronics design more than once will cause this. The problem seems to be module name conflicts.
  • bug
jorge_garcia
Hello @anranlioculus ,
I hope you're doing well. Would you be willing to share the file for review? I have a feeling you are correct but if I can give the developer something to test that will lead to it getting resolved much sooner.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
anranlioculus
r Error while saving TEST2.brd ...
Errors:
line 624, column 241: redefinition of name 'TEST1:R1' in tag <element>
Closed-Loop-Bot
Thanks for bringing this to our attention. We're investigating the issue, and you can reference ticket FUS-274400 when communicating with Autodesk to find out more. Once the status of this will change, there will be a follow-up forum post made.
