[Bug] Shortcuts unsync from macOS after some time
motla.design
motla.design
Hello!
This bug is around for some time now and I don't think it has been reported yet.
When using Fusion Electronics on Mac, after some period, typing cmd+z (undo) or cmd+maj+z (redo) or cmd+s does not work anymore - or worse, works inside an hidden tab (i.e. another project which is open).
The macOS menu turns blue when the shortcuts are pressed but have no action on the save / undo / redo icons on Fusion. I think there is a synchronization issue which happens after some time using the software.
The only workaround is to restart the software but it is annoying.
Romain
jorge_garcia
Hello @motla.design ,
I hope you're doing well. I have reached out to our QA team to see if they can duplicate this.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
SallyYang
Hi @motla.design ,
Thanks for bringing this issue to our attention.
When you encounter this again, could you please check whether the Fusion menu changes?
Also, is the problem limited to shortcuts, or does it also occur when using Undo/Redo/Save from the Quick Access Toolbar?
Thanks for your help!
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
