Bug - False errors for traces
shaische222
shaische222
This one is really annoying. I have a bunch of false clearance/overlap/etc errors that seem like a bug in the software. I will sometimes move, add or edit my board and all of a sudden a bunch of new clearance/overlap/etc errors show up such as the attached picture shows. These traces are clearly not an error and I never changed my board settings. Can you guys please fix this? It's annoying having to go through 100 error messages just to find the real errors, only to have it happen again once something is edited!! Huge waste of time. This never happened in eagle cad. I even tried rats nest command and it didn't fix it.
jorge_garcia
Hi @shaische222,
I hope you're doing well. Are you running the DRC or clicking on the ERRORS dialog? These seem like outdated errors.
If you use the ERRORS dialog it will always show the results of the last DRC run. Which 90% of the time is not what you want. Make sure to always click DRC.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
