- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I want to add a simple mechanical object (a rectangular solid) to my PCB. It has no electrical function, and thus so far doesn't exist in a library. It seems to me that I should be able to create the 3D object as a Design item, save it, and somehow add it to the 3D PCB document, but this doesn't seem directly possible, as the "Insert into Current Design" menu option is greyed out. I saw in a older forum post something about needing to put the 3D PCB into a Design Workspace first. I'm a seasoned Eagle user who is trying to leverage some of Fusion's 3D capabilities without turning simple actions into major projects!
Obviously, I can create the desired object in a library and add a 3D model to it, i.e. the Eagle way to do it. Given where Fusion is today, what are my other options for the above? What does it mean to put the 3D PCB and the 3D object into a Design Workspace? Does "Design" mean mechanical design, as differentiated from "Electronic Design"? And is this still the best way to do this, or is there simpler way now?
Scott
