Im' wondering if there is any tips to auto-increment a net name when inserting a schematic.
Basically here we have an I/O stage drawn into a schematic that we'll reuse mutilple times on a board. When inserting the I/O stage into let's say the "main board", we're are prompted with the window where we can rename the net if needed.
In our case we don't want all I/O to be linked together but to be separated, so we could each time rename each net for I/O-1, then I/O-2 etc... I'm wondering if there is any trick to name the nets into the schematics that will be inserted so when inserted in the main schematic FUSION will automatically append a number.
e.g.: LOAD_X inside the I/O stage schematic => when inserted FUSION will generate net LOAD_1, then on next insert LOAD_2 etc...
Thank you very much
PG
