Auto increment net's name when inserting schematic
pg.delest
pg.delest
Im' wondering if there is any tips to auto-increment a net name when inserting a schematic.
Basically here we have an I/O stage drawn into a schematic that we'll reuse mutilple times on a board. When inserting the I/O stage  into let's say the "main board", we're are prompted with the window where we can rename the net if needed.
In our case we don't want all I/O to be linked together but to be separated, so we could each time rename each net for I/O-1, then I/O-2 etc...  I'm wondering if there is any trick to name the nets into the schematics that will be inserted so when inserted in the main schematic FUSION  will automatically append a number.
e.g.: LOAD_X inside the I/O stage schematic => when inserted FUSION will generate net LOAD_1, then on next insert LOAD_2 etc...
Thank you very much
PG
jorge_garcia
Hello @pg.delest,
I hope you're doing well. I figure you have labels on those nets, would that be correct? If you do, the trick is to delete the labels, then every instance will auto-increment.
By design, any nets with labels displaying their name will preserve that name when inserted into a new design. If nets don't have labels they auto-increment. If you really want the labels then you can put them back once you have inserted as many instances as you need.
Let me know if you continue to run into problems.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
pg.delest
Thanks, I tested and it works fine. In other word changing a net name from something like N$0 to LOAD_0, when the schematic is inserted, FUSION will automatically increment the tailing number as long as the net does not have any label.
The little work around is then to add some manual text next to the net to immediatly know what it does, like we'd have a label.
PS: love the fact that on this forum we get very fast replies 👍
