Why I can't see the pad holes in printed PDF
18018016
Observer Observer
18018016
Observer
Observer
I print the pads via my PCB design. But, I can't see a hole in my printed PDF document. What is the problem?
CGBenner
@18018016
Welcome to the Community!  I've moved your post here for better results.  Could you share an image of your PDF print settings?  Maybe they will give some clues.
Chris Benner
Observer
Observer
This is my PDF Setting print.
jorge_garcia
Hi @18018016,
I believe this has been fixed in the latest version of Fusion, could you try updating to the latest release and see if you see the holes in the PDF output.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
CGBenner
@18018016 Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
