3D PCB Does Not Show Component Values
GabeKarlick
Message 1 of 11
GabeKarlick
Hello All,
My 3D PCBs are not showing any component values.  My 2D PCBs do however show component values.  Is there something I can do to fix this.   I have been searching online and haven't found any solution.  Also to note, the CAM preview does not show any component values.
Gabe
Replies (10)
Message 2 of 11
yqliu
Hello @GabeKarlick ,
The values are not showing on 3D PCB on purpose to make the board clean. We will consider to add an option to show the values in future release.
Message 3 of 11
GabeKarlick
Okay, how about the CAM view.  I suppose that is also on purpose.
Message 4 of 11
HelenChen-AutodeskQA
Hi  @GabeKarlick ,
Thank you for asking.
CAM Preview we don't show the component values by default, but in the CAM Processor > Output Files > Gerber > Silkscreen Top / Silkscreen Bottom > Layers > you could add the values layer there and then the Component Values will be shown up.
Hope it helps.
Please feel free to let us know if you need our further assistant.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
Message 5 of 11
robZDWS7
This reply makes no sense.
Certainly, the point of being able to turn layers on and off is to make things "clean". So allow us to turn on and off component values !!!
Please, this is a most basic thing that Altium did decades ago -- SHOWING COMPONENT VALUES -- so that prototype PCBs can be assembled on the bench using a printed sheet of paper with the component values on them.
Message 6 of 11
jorge_garcia
Hi @robZDWS7,
I think there is some form of misunderstanding here. You can show component values on the 2D PCB and print it for easy assembly. I do this all the time.
This thread revolves around showing the values in the 3D PCB which it currently does not show. It's an open feature request.
I'll add your comments to it.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 7 of 11
robZDWS7
Jorge, thanks. If you can indeed show the component VALUES in 2D, then how? Thanks.
Message 8 of 11
jorge_garcia
Hi @robZDWS7,
I hope you're doing well. See my response here:
https://forums.autodesk.com/t5/fusion-360-electronics/awful-unintuitive-and-buggy-cam-exporting/m-p/...
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Message 9 of 11
dave3PGN8
Since this is over a year later, perhaps this has been fixed. (It doesn't appear to be fixed by default.) This "feature"--showing component values on the 3D pcb is most basic and very necessary. One of the principal features to review on the 3D PCB is making sure the silk screen text is displayed how desired. For now I've had to change the layers of all the component values, putting them on the tNames layer so they'll show up in 3D. Please fix this!
Message 10 of 11
yqliu
We have provided an option to customize the silkscreen layer:
Message 11 of 11
dave3PGN8
Excellent, thank you!
