Awful unintuitive and buggy CAM exporting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Problem: I have a simple PCB and want to print onto paper the component overlay with values. Why? So that I can place the sheet of paper next to the PCB and assemble it.
Comment: Altium (Protel) could do this in about 5 seconds 30 year ago.
After trying for 2 hours to find a way to do this...
Solution: It seems there is no solution to for this. One forum thread says it is not implemented and it keeps the layout "clean" if you don't have component values scattered all over it. Well, sure, that's why you have layers and turn them off as required.
Then is suggests using the CAM output. Okay, select CAM Processor, go down to Image to produce a PDF and select the layers: Dimension + tPlace (20 and 21) and Process Job. The image files do not appear, even though about 10,000 other files do.
Why is this so **** difficult? Good grief, am I the only person on the planet who wants to simply print the top overlay???
