Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Creation of 2 devices imported from only one
1 REPLY 1
valit22
81 Views, 1 Reply
Hello!
I am a very new user of Fusion 360 Electronics, and even of electronics in general.
For several days I have been struggling to create a library with two devices derived from a single imported one (for example ESP-01) in my own library. I imported a device that contains a symbol and a footprint, to which I added a 3d package. So far everything works perfectly. The problem appears when I try to create a similar device, with the same footprint and symbol, but a different 3d package with the only difference that I want to attach a pin header (2x4) to it. Whatever I do, I cannot create two devices imported from one, with two different 3d packages. The two devices share the same 3d package, when I change one, the other one changes as well. I hope I explained clearly what I want.
Is there any way to achieve what I want?
Thank you!
1 REPLY 1
valit22
in reply to: valit22
In the end, I understood what path I should follow. The solution implemented in the application is much better than the one I was following. The secret was "create new package variant" from the components tab.
Thanks!
