Using If statements and Logic operator for cutting patterns
jonathanYY8UL
jonathanYY8UL
Hi all,
I'm trying to use an If statement in my parameters to cut a hole in an object. Basically what I want to happen is If my length is 0-1" I don't want to cut a hole, If the length is 1-2" I want to cut 1 hole. Is there a way to have an extrusion not happen in an IF statement, essentially making my instances of an extrusion/pattern 0?
kellings
Hi @jonathanYY8UL This isn't currently possible. However, there is some future functionality that should accomplish what you are trying to do. I can't speak with specifics on unreleased features.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
