Tubing Specs
Tubing Specs
Message 1 of 22
Tubing Specs
Are there Tubing Spec Catalogues, for items such as Swagelok Fittings, to be able to route tubing as you would Piping in AutoCAD Plant 3D?
Replies (21)
Message 21 of 22
ZZikic
Perhaps, but you can never process all those at one time.  I still prefer to work in manageable chunks.  Also, I've never seen a tubing spec requiring every single fitting available in the catalog.  Maybe a hand full?  I understand if you are building a "master" catalog but even so, a majority of those 500+ components, will they actually be required in a spec?
Message 22 of 22
quan_hm
