I would like to have my students share their projects with me for grading purposes. After reading the product documentation on sharing, I feel like I'm seeing something different than what was described.
This is what I see in the data panel when I choose "People":
It wants to kick me out to the web to view and manage the members of the project. I guess that's fine, but the documentation says you can send the invite right in the data panel under "People".
Am I doing something wrong? What's the best method of having students share their projects with me.
Thanks in advance for your help.
Solved by dan.banach. Go to Solution.
Hi @andersonto
Sorry for the confusion. The product documentation shows the current commercial experience. Earlier this year we implemented Folder-Level Projects for Education accounts. Here is a sneak peak to a video I just created about Folder-Level Projects that demonstrates how to setup a Folder-Level Project with roles in a classroom.
This video should get posted next week, then I’ll pin a post with these details. Please let me know if the video is helpful.
-Dan
I had the same question. Your video has a workflow where the instructor invites the student to their project. I have been working the other way, where students create the project then invite me. I've found the only way I can access their projects in the desktop application is if they make me project admin. Is this correct? Otherwise I get a message my access is denied.
It seems random, too that the "old" method of inviting members to a project in the desktop app still works, this method is flawless and I can get access to their projects folders, etc with no problem. Other students must go to the web browser Teams site to make the invite, then the admin role seems to be required for me to see the projects.
Any insights?
Hi @eng491
Great question. With an Autodesk Education account, if a Fusion 360 project was created prior to January '22 it would have been a legacy Closed project. With this project type, anyone invited into this project can do whatever they want. If a legacy project is active, you can still invite others directly from the Data Panel. You can still create this project type, it just needs to be created from Fusion Team.
To access a project, you do NOT need to be an Administrator. I'd like to learn more about the project type that the students created and how they invited you. With a Folder-Level Project, the students would go through the same process as I showed in the video, but invite you.
Here is a link to an article that I wrote that goes into more details than I did in the video: Working with Fusion Team and Folder-Level Projects.
Let me know if this helps.
-Dan
Here are images showing what's going on.
1. The student's screen. It shows he's invited me and my role is a team member.
Here is my screen on the desktop for Niko. I get the message "Failed to fetch folder contents".
And my screen on the web browser for Niko's team. I get the message "you don't have required permission to perform this operation" and "error loading data".
My solution to this has been to have the student change my role to administrator, then I can access their files both on the desktop and web browser version.
Thoughts?
Hi @eng491
Thanks for adding the images. It looks like the student added you to their Fusion Team as a Team Member, which is correct. The missing piece is that the student needs to invite you to a their project. Please ask your student to do the following.
Hope this helps.
-Dan
