How to Set the Parameter value for Python Custom Script ?
Message 1 of 20
Hi, Experts
Following is a part of my Sample Python Script
from aqa.math import *
from varmain.primitiv import *
from varmain.var_basic import *
from varmain.custom import *
# Write Metadata Section
@activate(Group="Support", TooltipShort="SAMPLESUPPORT", TooltipLong="SAMPLESUPPORT", LengthUnit="mm", Ports=1)
@group("MainDimensions")
@param(D=LENGTH, TooltipLong="Pipe Diameter")
@param(SL=LENGTH, TooltipLong="Plate Length")
@param(SW=LENGTH, TooltipLong="Plate Width")
@param(SH=LENGTH, TooltipLong="Plate Height")
@param(VOL=LENGTH, TooltipLong="Plate Volume")
def SAMPLESUPPORT(s, D = 100, SL = 1000.0, SW = 2000.0, SH = 3000.0, VOL = 0.0, ID = 'SAMPLESUPPORT', **kw):
    box = BOX(s, L=SL, W=SW, H=SH)
    VOL = SL * SW * SH
VOL is a parameter which I want to set the volume of box after I create the box and I expect the VOL parameter to be changed according to the variable value of Width, Height, Length of the box.
(VOL = SL * SW * SH) is not effective because VOL always stays same as zero(0)
Thank You.
Replies (19)
Message 2 of 20
h_eger
I only have one question:
Where did you get the information from custom Python scripts for the construction of Autodesk AutoCAD Plant 3D objects?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 20
jabowabo
There isn't a documented function that will accomplish this. The parameter values do not update based on what happens in the body of the script* - they only read what is defined in the params line.
*The setLinearDimension function does update the parameter values but it feeds them back into the params line.
Message 4 of 20
Thank You, Jabowabo
Message 5 of 20
mikael.santospj
Hi GUYS, HOW ARE YOU ALL
I don't know if this is the right thread to ask this, but we have an inline instrument whose flange face to face distance is variable. I would like to insert this item in the instrumentation spec and let the user define this distance in the properties of the component. Is that a way to do that other than the custom part?
Message 6 of 20
h_eger
Dear @mikael.santospj ,
With it your wishes come true
# 2 - "Parametric" Component Designation
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 20
mikael.santospj
Thanks, you are absolutelly right, that's it.
Message 8 of 20
mikael.santospj
Only to show, we do need this customization for PSV's and control valves in the instrumentation spec, for example.
Message 9 of 20
jflorita
Hello everyone,
I would like to share that I have developed a customized support system using Python script. However, there is a certain parameter that is optional, and I intend to have it hidden if the value of the parameter is zero. Unfortunately, it appears that I am unable to input zero as a value.
Thank you
Message 10 of 20
h_eger
Dear @jflorita ,
I don't know any way to do this.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 11 of 20
jflorita
Thank you for your response @h_eger
Message 12 of 20
theshoaib.mughal
I hope I am in the right forum. Could anyone guide me if it's possible to change the component family description on-the-go?
Let me explain the need. I have  coded the cable tray script that allows from switching between solid bottom, perforated bottom and ladder type after they are placed in the plant3d. I have defined a parameter that listens to these changes. And it works fine. Although for my BoM and isometric I like to change the component description as well with these changes so that the BoM represents the part that is currently placed in the model. Trouble is that this information is stored in the metadata whereas the changes to shape happen in the body of the code. Is there a way to access the metadata and change it from the body of the code.
 e.g.
Shape =0 means solid
Shape =1 means perforated
Shape =2 means ladder
So if i choose either value, the IF loop in the code executr relevant portion only and i get the desired result. I wonder if I could insert a code line for changing the component description in these IF loops.
Any thoughts??
Message 13 of 20
theshoaib.mughal
One more thing. Is there a way to make a copy of an object. I hate to code same components over and over. If i could make a copy and move it with translate command then it will be a treasure
Message 14 of 20
jabowabo
 e.g.
Any thoughts??
There is no link between the two. You would need 3 different spec items with different descriptions if you don't want to modify them in the model.
This can only be automated via the .NET API. Related info: https://forums.autodesk.com/t5/autocad-plant-3d-p-id-ideas/where-we-can-get-dimensions-of-python-scr...
Message 15 of 20
jabowabo
I don't think it's possible to copy items. You can import items from other scripts multiple times though: https://forums.autodesk.com/t5/autocad-plant-3d-forum/custom-python-supports-calling-other-custom-sc...
Message 16 of 20
theshoaib.mughal
3 specs is kinda long way around although it gets the job done but the other option seems promising. I will give that a try and see what happens.
Message 17 of 20
theshoaib.mughal
Hmm. Thats a thought. Not suitable for my current problem as i want copying the object created in same script. But its gonna be useful in other because most of the begining blocks for creating shapes are usually simple and same. It can help me there. Thanks 😉
Message 18 of 20
jabowabo
Three items, based on the same script with appropriate shape values and descriptions, in one spec.
Message 19 of 20
theshoaib.mughal
Hello guys. One quick question. I have to work with reducers. I added 'custom' in the specs editor so I can the parameter in the drawing. Now this has caused a trouble. The component size in the catalog and specs was 300x100 (in mm) so port 1 was 300 and port 2 was 100. If I place it as is then its all good. But if i change size of either port say e.g. make it 400x100 the two things happen;
1. Since the '+' sign adds a corresponding pipe to the port; it doesn't add a corresponding 400 size pipe instead it adds a 300 size pipe which is default size of the component. I want it to add a 400 size pipe
2. The description of reducer in isometric is still 300x100 even if I manually add a 400 size pipe. How can I change the description of port size to 400x100 in this case?
I know there maybe a reducer defined for 400x100 size but what if there is a size that isnt defined then what??
Message 20 of 20
jflorita
Hello @theshoaib.mughal
I think you should make a new post regarding your concern. This thread is for python scripting, and it is also marked as solved, but I'll answer it anyways.
What you changed were only the parameters of the 3d model, if you want to change the size you have to do it in the spec editor, else it won't work. If you want a 400x100 then register it, you can't change nominal sizes of components in the properties.
