How to move projects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
For posterity, here's how to work around the problem with Fusion's educational licensing regarding project transfer.
Say you have a project you want to transfer from one "team hub" to another. Say the source is your personal hub, and the destination is your school's hub.
If you created the project using the educational license in the f360 GUI, there's no "transfer" button because the "folder" type of project doesn't allow that, and doesn't allow the type to be changed, and doesn't give you any clues to any of these problems.
So to make it work, do the following:
- in the f360 GUI, find a file that includes everything you need, perhaps as dependencies. in my case the are a bunch of separate component files and a top-level "assembly" that references everything.
- go to "File > Share", and get the sharing link that leads to the public web 3d view thing
- click "download" as an f3z file. this contains the shared item as well as anything it depends on.
- go to the autodesk web team hub thing that shows the destination team
- create a new project there; give it something other than "folder" permissions
- go back to the f360 gui and find the project you just created
- click "upload" and choose the f3z file you just made
- after awhile all the files will appear in the destination project.
you should never create new projects in the f360 gui. create them only using the web admin tool, otherwise they get stuck in "folder" mode and can't be transferred later.
if any employee of autodesk ever reads this, i'd appreciate talking with you about how to streamline this process.
