Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Organizing components in browser not as subfolders just moving their order
2 REPLIES 2
patrick_william
163 Views, 2 Replies
There are tutorals of making subfolders, but I just want to  move components around in the browser not based in  how they were made ( first created on the upper and later created on the bottom) . Can we just arrange the browser components and not effect the time line and not as subfolders, just click drag and drop in between other components?
2 REPLIES 2
kellings
in reply to: patrick_william
Hi @patrick_william You will find there is a limit to how much you can organize your browser. You will be limited by your history on what is allowed to move where in the browser.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
patrick_william
in reply to: kellings
Good to know. Next time, I will need to have that in mind before propagating the browser as to not have to scroll up and down for components.  thank you... learning the limits is freeing.
You've got Fusion.
