You have chosen to print x view/sheets as separate files.
Does anyone know how to turn this dumb pop up off?? There is zero reason for it and I wish it never showed up. If you are trying to print a sheet, you are doing it for a reason. Any help would be great. It was not in v.2014 but it is in v.2016. Thanks,
Ryan
innovatenate
Autodesk Support
Autodesk Support
Welcome to the Fusion community page. Could you post a screenshot of the dialog? What command are you using to generate it, Output to PDF from the Drawing Environment?
Nathan Chandler
Principal Specialist
