Working with SVG Files
Message 1 of 22
I am making some sheet metal coasters with an SVG file using a plasma cutting table.
I imported an SVG from Illustrator. I modified some lines. Now the lines that I modified won't show as black for cutting. The holes show up, which I did not modify. Screen Shot 2021-09-18 at 7.39.49 AM.png
Replies (21)
Message 2 of 22
mango.freund
measure all lines and radii. voila
Message 3 of 22
TinWhisperer
You should be able to use that exactly the way it is.
Bring your sketch geometry into the manufacturer workspace. Make sure your sketch is not hidden.
When you bring up your 2D profile menu you should be able to select your geometry there there is some nuance to selecting all the individual little lines that make up one line so it cuts as one line.
If you posted your file I can walk you through the steps.
I did make a topic on the langmuir systems forum site discussing this I'll see if I can find it
Message 4 of 22
TinWhisperer
Is this similar of how it turns out in F360 for you?
Message 5 of 22
TinWhisperer
With no constants, no measurements , no extrude you should be able to generate tool paths like I did here with only sketch geometry.
Split into 3 operations.
it is 4 x4 inch but I did not define any dimensions in the sketch. did enter a z height in manufacture set up.
Maybe there is something off with your SVG . post it and lets find out.
Message 6 of 22
This doesn't seem to work for me.
Message 7 of 22
I will give this a try. My frustration is that I only use my Langmuir machine a few times a year and Fusion 360 changes so much that the terminology changes. The original Langmuir videos are almost irrelevant now.
Message 8 of 22
Not quite. I don't get the dots on the ends of the lines.
Message 9 of 22
I will get back to this later today. I have fall yard work to get done. Thanks for the posts so far.
Message 10 of 22
TinWhisperer
Go on to langmuirs forums and post on there post your SVG as well and I'll walk you through the whole thing.
I also own a langmuir crossfire pro.
You'll be able to find my avatar on there pretty unmistakable.
If you give me the parameters for the plasma torch you'd like to run I could just post a NC file and at least you could get this project behind you
Message 11 of 22
Heading in to the Langmuir forum now. Fusion 360 area.
Message 12 of 22
Here is the .dwg and .f3d file.
Message 13 of 22
TinWhisperer
Here is a method of getting CAM completed for that file .
I did modify this image some the clearances felt too tight to be producible.
here is a walkthrough from your DXF to NC file
https://www.loom.com/share/b25d3f406ebe4a92bb434726d89dc8f8
I programmed this to run with a standard 45 amp Duramax consumable pack  Kerf of .055
simulation
https://www.loom.com/share/52dc7710e0064773b4d04e067ef94ec1
For the Langmuir System Owners I went through this at that forum too
https://forum.langmuirsystems.com/t/svg-file-challenges/17135/8
Message 14 of 22
Thanks!! You really know what you are doing on this stuff. Very much appreciated.
One quick question, when you were selecting the blue lines for the 2D profile, a little "box" popped up after you picked the first part of each line. What is that?
Again, BIG THANKS for your support. You are really helpful!
Message 15 of 22
g-andresen
You can also select the sketch completely.
Then you don't have to click on individual lines.
günther
Message 16 of 22
TinWhisperer
You are very welcome.
it gives you some options when selecting individual lines.
You can select this blue line
and you could continue to select these path segments.( they will cut individually too )
Or
Double click that line (path) piece
now each piece you select will join together and cut as one path
Or double click again and it will select all the path that is connected  ( I prefer this )
typically when making these kinds of cuts you also also want to set your Side ways Compensation to Center
And also select no lead in or lead out and pierce to Clearance to Zero in in this menu.
Split up your cutting operations for your best success.
Group like operations.
Please post some pictures when you cut these.
Message 17 of 22
TinWhisperer
günther
May you please demonstrate this method, I have not done it that way before.
Always looking for better ways to speed up my workflow.
Message 18 of 22
g-andresen
this way
günther
Message 19 of 22
TinWhisperer
I see.
How does that separated The chosen paths into two operations ?some that are center cutting and some that are left sideways compensation cutting like my example above?
Easier to compare the two methods when they have the same outcome.
I'm also wondering because you're using a different post processor in your setup because you're doing carving, if it might the link and select differently than the post processor used for the langmuir systems plasma table?
Langmuir Systems Post Processors
It's the langmuir crossfire pro THC IHS
Message 20 of 22
g-andresen
For different operations, the sketch in design mode must be separated into partial sketches accordingly.
I do not use any PP.
I have shown a TRACE operation and not an ENGRAVE.
Instead of TRACE you can also use CONTOUR:
günther
