I am helping a biddy re design an airsoft stock. I am tring to create a hole in the what is labeled back of this model. If you look inside the tube there is a hole that goes straight down for a sping loaded switch. I need ahole in the "back" to get a screwdrive down to the screw. I projected the geometry to the back and sketched a hole but it will not let me cut the hole. So whaty am I doing wrong?
Can you share the original model before your edits?
This model consists of a large number of unstitched surfaces. Even when stitching everything visible in the viewport, that doesn't result in a solid body. More work is needed to turn it into a solid body.
Also, you should not work with the timeline turned off.
After importing the .igs file, turn on the timeline, and then stitch all the surfaces into a solid body.
Then continue with your edits.
If you run into trouble, share the model again with your edits in place.
Ok great thanks I did what you said and I was able to do my edits I need. So now it looks like I have one solid body (my edits) and one Surface body. I say this because the body icons are white and orange. So if I try and 3d print his object my edits are going to be a seperate print (or not joinedto the orginal right? I extruded elements from the orginal and used the join command so I dont understand why these are not one body. I tried a combine but it wont let me selet the surface body. If you can look and tell me what I am doing wrong here. I truly appreciate your help!
I think it would be of tremendous help for you if you completed at least one of the introductory Fusion courses here:
This project is a good bit beyond your current skill level and you need a solid foundation in basic CAD concepts before moving forward!
When you are in the surface tab and start deleting surfaces from a solid body that creates an open surface body.
That will obviously not 3D print.
When you are in the solid tab and select one, or more surfaces, Fusion will attempt to delete the surfaces and auto-heal the solid so it remains a solid.
I did that in the attached model.
Roll the timeline back all the way to after the stich icon and move it forward step by step. edit each of the features in the timeline to see what faces were selected and what the end result of the operation is.
I have taken several Youtube courses and no i am not anywhere near good enough but this is a project for a friend and I figured I could edit this file. I know that .igs files are surface files not sure why one would model with that since they can't be printed but I thought after you stitched it up it becomes a solid model. That said the icon never changes to the solid body icon. So is there a way to combine these bodies are have I wasted my time? Should I edut the model in solid, which is where I thought I edited that model in? Is there a youtube or somewhere I can watch on how to edit iges files to solid.
I opened the latest model you posted. if you roll the history marker back to right after the stitch, you'll see you had a solid. then you deleted a surface while in the surface tab, which converted it back to a surface body.
Please re-read my post in it's entirety and follow the instructions.
E.g. Go through the timeline and edit each step to see what how that step (feature in the timeline) was created.
As I've already described, when you are in the surface tab and delete one, or more surfaces from a solid body, that creates an open surface body.
That is what you did in the first step after stitching the surfaces into a solid body.
If going through the timeline does not provide you with the needed info, I can create another screencast.
