Workflow using rectagles as guides
Message 1 of 8
Here is what I like to use as my work flow.
1) Create new sketch.  name this sketch-constr1
Draw rectangles of boundaries for actual 2D objects I want to create.
These are not the shape of actual object, just the outer limits of actual object footprints.
I like this to be my construction rectangles, but not able to find such option.
Ideally, I can click anyone of these rectangles and convert this into "construction rectangles".
How?
2) Create new sketch (folder). Name it sketch-object1.
This sketch would be inside one or more of the "construction rectangles" in 1) above.
Again, F360 is not aware of "construction rectangles" being used as such.
Now I can draw on one of the above "construction rectangles".
3) Repeat 2 (for another actual sketch object, sketch-objectX ,where X=object number.
4) When all is done, I would hide all the construction rectangles.
Is there a better way to mimic these construction rectangles on F360?
Replies (7)
Message 2 of 8
TheCADWhisperer
Right click to toggle to construction.
or
hit
x
If you would like to reference geometry from one sketch (or body)  into another sketch
hit
and select the geometry to Project.
Message 3 of 8
@TheCADWhisperer:
Thank you.
With or without edit sketch mode, I selected each rectangle, and right click.
There is no convert to "Construction..... " or something similar option.
How did you make Normal/Construction menu item to display?
Message 4 of 8
TrippyLighting
You cannot change sketch elements to construction lines if you are no actively editing that sketch.
And it has to be THAT sketch you are editing, not a second sketch on  top of the first one with projected points (indicated by the purple color!.
Message 5 of 8
@TrippyLighting:
>>"You cannot change sketch elements to construction lines if you are no actively editing that sketch."
OK.
So here is what I did.
1) I selected the rectangle or the corresponding sketch folder.
2) Right click, and > edit sketch  (So this makes the sketch active, correct?)
3) When the Sketch Palette pops up, there is no Normal / Construction option.
I also try this while in above active sketch for that sketch folder:
-Draw new rectangle
But the sketch palette did not show Normal / Construction option.
Why?
Is my Fusion 360 outdated or does it update itself?
Addendum:
SOLVED:
I think I know what I did wrong.
While in active edit sketch mode, I have to select
the line of the rectangle.
Then right click to select Normal / Construction.
Also Normal / Construction  will automagically show up on the Sketch Palette
while the line (in edit mode) is selected.
Thank you @TrippyLighting & @TheCADWhisperer
Message 6 of 8
TrippyLighting
Your Fusion 360 installation is not outdated as that is hardly possible. Updates are forced.
This functionality has not changed in the lat 6 moths or more.
Did you watch my screencast ?
Try to exactly replicate it. That should not be difficult as I am starting from scratch.
Message 7 of 8
Got it.
Message 8 of 8
@TrippyLighting, @TheCADWhisperer:
>> "If you would like to reference geometry from one sketch (or body)
into another sketch hit p and select the geometry to Project."
Are you referring to creating a projection plane,
and then project the line to the new plane
or something else ?
