IGES files seem to be empty
Bill_Brehm
Message 1 of 14
Bill_Brehm
When I upload IGES files, and then open them I get a blank screen.  No problem with other file types, but the time line is only supported in a few file types.  IGES is the only supported file type I can save drawings as.
Never mind Problem solved
Replies (13)
Message 2 of 14
innovatenate
Autodesk Support
Autodesk Support
BREP (solid or surface bodies) are supported. Mesh and Sculpt (T-splines) bodies will not export to IGES. Not sure if that's what the issue was, but I hope this helps.
Nathan Chandler
Principal Specialist
Message 3 of 14
Bill_Brehm
Thanks Nathan,
That was it.
Bill
Message 4 of 14
Hi;
Same problem for me.
I'm a novice so be patient...
I have opened a project, a .stp file, and I want the iges file overlaid on the other file. There is nothing there. There is data in the file but Fusion 360 does not see it.
... any ideas?
Message 5 of 14
innovatenate
Autodesk Support
Autodesk Support
Welcome to the Fusion Community!
Which method are you using to open the file? See the below link for reference.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Is it possible to share the STEP or IGES file that is giving you trouble?
Nathan Chandler
Message 6 of 14
Bill_Brehm
Sorry, you where replying to pkihome
Thanks Nathan,
I was trying to use the wrong (in my case) format to import sketches.  The dxf format work perfectly.
Bill
Message 7 of 14
Hi;
Thanks for the quick response.
I have opened a project, its an STP file.
Then I want to overlay a IGS file in the project. The IGS file has the exact location of some holes so I can build around the holes.
However when I load the file there is nothing there...?
I have used the cloud to upload the file (holes.igs) then it shows up in the data in my folder panel. I have tried to drag and drop in the open STP file. (nothing there).
When I do drag and drop the IGS file into the open STP file it  (the holes.igs file) shows up in my project browser, but nothing shows up on the STP image.
Used the 'new design from file'(nothing there).
I have attached the IGS file see if you think it is valid.
I tried to up load the .igs file but the posting message page will not allow a .igs file (I get an error).
How would I send you the .igs file in question?
How would I convert the .igs file to a a valid format to load?
Phillip
Message 8 of 14
Bill_Brehm
Phillip
I think you meant to address this to Nathan.  Smiley Happy
Bill
Message 9 of 14
innovatenate
Autodesk Support
Autodesk Support
With the other design open, can you try right click on the design (IGES) file in the data panel and select the Insert into Current design command?
The IGES file didn't appear to be attached, do you mind uploading again?
I hope this helps!
Nathan Chandler
Message 10 of 14
I tried to upload it and the 'reply to message' would not allow the .igs format, and gave me an error.
I have attached it again.
I tried the method you described and that showed up in my browser tree, but nothing I could see.
Your messaging system will not allow a .igs file. Please advise...
Phillip
Message 11 of 14
innovatenate
Autodesk Support
Autodesk Support
@Anonymous I still did not see the attachment. It may help to compress the file into a ZIP file before uploading it.
I hope this helps.
Nathan Chandler
Message 12 of 14
Hi Nathen;
This is the holes.igs in a zip file.
Let me know what you think.
Phillip
Message 13 of 14
innovatenate
Autodesk Support
Autodesk Support
I opened that file up in Inventor. All that is in there is some sketch geometry (wires). There's no solid geometry for Fusion 360 to import. Could you get the file in a different file format like DWG or DXF?
I hope that helps!
Nathan Chandler
Message 14 of 14
my inventor2016 just looks like transparent when add stp file, do you know how to fix it
