Message 1 of 12
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm new in using the form mode and try to find a structured way to approach this design. The 4 legs should all join together underneath the table in a similar shape. The leg with the Blue patch is close to the final shape I'd like. Is there an easy way in the form mode to copy the structure of this leg onto the other 3 ?
I used sweep to get the connecting part, which is also the smoothest part..
I'm spending hours between modify, cilindrify to get a smooth model. I guess I could do it in the parametric mode but I like the fact that I can do small adjustments afterwards.
Any suggestions are welcome,
Thanks in advance
Best regards,
Ruben
