Woodworking joints in the workflow
luca.dalmo
luca.dalmo
Hi all, second post from my side as I'm slowly progressing in learning this wonderful software.
So here's my question;
Let's say I want to build a table with four legs. I create a leg component and I make duplicates. These are then parametric and so far so good. If I want to start sketching a tenon or a mortise, these will only reflect on that single component where they are sketched and not on the copies.
I undestand that this sketch belongs to that single component and not the copies and I'm sure there's a valid reason for this. But....is there a workaround to solve this issue? I tried to mirror but same result.
The only thing I can think at the moment is to draw the joinery on the leg component before I make copies?
Thank you for your attention and please see the attached file.
Luca
jhackney1972
If you right click on a component in the browser and select Copy from the menu, then right click in the design background you will get two options, Paste and Paste New.  Paste will give you a true copy of the component which is associatively hooked to the original.  If you drill a hole in the original, the hole will appear in the copy.  If you use the Paste New option the copied component is an entirely new component that carry the features of the original component at the time of copy but will not change if the original is changed, it is un-associative.
John Hackney, Retired
g-andresen
This should be the preferred route.
In this case you can still drag the sketch into the component to achieve the same effect.
günther
luca.dalmo
Hello, I did a couple of trials and it works with both methods.
Thank you,
Luca
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
