will motion limits work with + and - values together?
safiredesignengineers
Hi Group
can motion limits work with + and - values together?
i.e can i have a +4 value for minimum and a -14mm for a maximum with a 0 value for the rest position?
As When I try to use this mix of + and - all the boxes = the same value...?
I .e if i place +4 in minimum, then as soon as I type -14 in maximum the minimum value and the 0 value change to -14mm??
is this correct or a bug?
A
g-andresen
No!   Minimum  (-14 ) < Maximum (4)
günther
Hi günther
so the values only work as a numerical value i.e the higher value needs to be a higher number.
As opposed to working from the datum position which is zero and anything on one side is a negative value and on the other side is a positive value?
However I can't Flip the directions so my option is to move the datum, is this correct?
A
