Why isn't my sketch constrained?
SuzukiGS750EZ
SuzukiGS750EZ
None of the dimensions in my sketch are defined and black. What can I do to define them? I've tried adding dimensions to all the lines, constraints, etc. Nothing seems to turn them solid black.
jhackney1972
When you are in doubt, left click on an entity and drag it.  You will see what you need.
John Hackney, Retired
Drewpan
I would strongly recommend that you do the embedded tutorials in the Fusion Documentation and also some of the
Self-Paced Learning to help you to learn fusion faster and better. They can be found here:
It is also much easier for the forum to help you if you attach your file AND a screenshot of what you want to achieve
and what the problem is. You can create a file to export like this:
Time spent on the tutorials and self paced learning will not be wasted. Also check out the three RULES that are pinned to the forum for further guidance.
One other thing you can do is use the Text Command Sketch.ShowUnderconstrained. This will show you all of the
lines and points that are not constrained or dimensioned.
Cheers
Andrew
g-andresen
This is how I would do it
günther
Christoph_360
Hello
@Drewpan  wrote:
One other thing you can do is use the Text Command Sketch.ShowUnderconstrained. This will show you all of the lines and points that are not constrained or dimensioned.
Thank you very much for pointing out this important Text Command Sketch.ShowUnderconstrained in the forum.
I wonder if it is not possible to make this command, so important for beginners, more visible in the interface.
Christoph
SuzukiGS750EZ
When I add the arc dimensions, it doesn't give me the points on the end (Edit: Figured this out. Have to pull down from top and up from bottom). I also can't get the horizontal/vertical to allow me to place it. Everything else I can do!
SuzukiGS750EZ
Figured it out! I ended up combining both video's teachings and got it to work. I did a coincident to the bottom left 6" line to the vertical 12" line. I did a colinear then from the two left 12" lines on top of each other and one more coincident from the center point of the intersecting construction lines to the origin point. Thanks all!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
