Why isn't my sketch constrained?
SuzukiGS750EZ
SuzukiGS750EZ
None of the dimensions in my sketch are defined and black. What can I do to define them? I've tried adding dimensions to all the lines, constraints, etc. Nothing seems to turn them solid black.
jhackney1972
When you are in doubt, left click on an entity and drag it.  You will see what you need.
Constrain Sketch.mp4
Video Player is loading.
Current Time 0:00
Duration 1:21
Loaded: 12.19%
Stream Type LIVE
Remaining Time 1:21
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    John Hackney, Retired
    Drewpan
    I would strongly recommend that you do the embedded tutorials in the Fusion Documentation and also some of the
    Self-Paced Learning to help you to learn fusion faster and better. They can be found here:
    It is also much easier for the forum to help you if you attach your file AND a screenshot of what you want to achieve
    and what the problem is. You can create a file to export like this:
    Time spent on the tutorials and self paced learning will not be wasted. Also check out the three RULES that are pinned to the forum for further guidance.
    One other thing you can do is use the Text Command Sketch.ShowUnderconstrained. This will show you all of the
    lines and points that are not constrained or dimensioned.
    Cheers
    Andrew
    g-andresen
    This is how I would do it
    add constraints and dimensions.mp4
    Current Time 0:00
    Duration 1:11
    Loaded: 13.85%
    Stream Type LIVE
    Remaining Time 1:11
    1x
      • Chapters
      (view in My Videos)
      günther
      Christoph_360
      Hello
      @Drewpan  wrote:
      One other thing you can do is use the Text Command Sketch.ShowUnderconstrained. This will show you all of the lines and points that are not constrained or dimensioned.
      Thank you very much for pointing out this important Text Command Sketch.ShowUnderconstrained in the forum.
      I wonder if it is not possible to make this command, so important for beginners, more visible in the interface.
      Christoph
      SuzukiGS750EZ
      When I add the arc dimensions, it doesn't give me the points on the end (Edit: Figured this out. Have to pull down from top and up from bottom). I also can't get the horizontal/vertical to allow me to place it. Everything else I can do!
      SuzukiGS750EZ
      Figured it out! I ended up combining both video's teachings and got it to work. I did a coincident to the bottom left 6" line to the vertical 12" line. I did a colinear then from the two left 12" lines on top of each other and one more coincident from the center point of the intersecting construction lines to the origin point. Thanks all!
      Type a product name
      ______
      icon-svg-close-thick
      Cookie preferences
      THIRD PARTY SERVICES
      icon-svg-hide-thick
      icon-svg-show-thick
      Qualtrics
      Akamai mPulse
      Digital River
      Dynatrace
      Khoros
      Launch Darkly
      New Relic
      Salesforce Live Agent
      Wistia
      Tealium
      Upsellit
      CJ Affiliates
      Commission Factory
      Typepad Stats
      Geo Targetly
      SpeedCurve
      Qualified
      icon-svg-hide-thick
      icon-svg-show-thick
      Google Optimize
      ClickTale
      OneSignal
      Optimizely
      Amplitude
      Snowplow
      UserVoice
      Clearbit
      YouTube
      icon-svg-hide-thick
      icon-svg-show-thick
      Adobe Analytics
      AdWords
      Marketo
      Doubleclick
      HubSpot
      Twitter
      Facebook
      LinkedIn
      Yahoo! Japan
      Naver
      Quantcast
      Call Tracking
      Wunderkind
      ADC Media
      AgrantSEM
      Bidtellect
      Bing
      G2Crowd
      NMPI Display
      VK
      Adobe Target
      Trendkite
      Hotjar
      6 Sense
      Terminus
      StackAdapt
      The Trade Desk
      RollWorks
      Your experience. Your choice.
