Why doesn't this simple sweep operation work?
I am only trying to sweep the shape of an ellipse through a spiral curve and I am not given the "ok" button to complete operation.  Can someone please advise?
Cere
WHolzwarth
IMO it's not possible, as it exists.
- Section needs to be placed orthogonal relative to path
- Path is too narrow, compared to size of section.
Walter Holzwarth
TrippyLighting
That is not a spiral curve. That is a projection of a conical 3D helix projected onto a flat plane.
Then you deleted the original,whihh is the reason for the yellow highlighted sketch warning you that it's references (the 3D helix) is missing.
What @WHolzwarth is saying is that this sweep would result in self intersecting geometry.
Ok, thanks.  I finally figured this one out.
