Why does the shadows keep moving when an assembly is animated?
http://autode.sk/2hkkRMw
Please watch the above video where i have showed the problem
paul.clauss
Hi @Anonymous,
Welcome to the Fusion 360 online community! Thanks for posting!
Without your Fusion design file it is hard to say what might be creating this issue. Do you have any hidden sketches or bodies? Perhaps one of your joints could be referring to hidden geometry and is creating this problem.
I am happy to take a look if you could share the Fusion design file with me. To do so, please use any of the techniques shown at this link!
Kind Regards,
Paul Clauss
Product Support Specialist
paul.clauss
Hi @Anonymous
Thanks for sending the file over! I was unable to find anyway to eliminate this issue apart from turning off "Ground Shadows" in the Display Settings > Effects settings at the bottom center of the Fusion 360 window. This does not really resolve the problem, but it does remove the distracting visual effect by fully removing any shadows.
As I could not find anything in your model that should have led to this behavior, I have logged an issue (FUS-29907) with our development team. They will be looking into what may be causing this error.
Paul Clauss
schneik-adsk
I suggest you turn off the adaptive ground offset.
from the display setting menu at the bottom of the graphics window, choose ground plane offset:offset ground off.png
Disable adaptive offset.
Kevin Schneider
Thanks for that @schneik-adsk , even thats not working i guess if my work procedure is right in the following link ( http://autode.sk/2iNOZju ) . Also in that video link i have shown tat the adaptive option is enabled automatically and the offset distance is reset to zero.
