How do you change the dimension of a line?
In sketch mode.  You draw a single line.  How the hek do you change the dimension?  Why is this so difficult?
Beyondforce
Hi @Anonymous,
Welcome to Fusion 360.
From the Sketch menu look all the way down, you will see the "Sketch Dimension" tool or just hit the "D" key shortcut.
Perhaps you should go to the Fusion 360 learning page and learn how to use Fusion 360: http://help.autodesk.com/view/fusion360/ENU/
Good luck.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
TheCADWhisperer
@Anonymous wrote:
In sketch mode. ...  How the hek do you change the dimension?
Double click on the dimension to change the value of the dimension.
AutoDesk99UGT
that gives an idiot error that says it violates the length constraint, which, of course, is what you are trying to change.
Unbelievable someone could even WRITE software like this without QA even looking at it.  Hardest app I've used since... Oh, yeah, Auto-Sketch from years ago.. It was designed to be harder than holy heck to use to.
So, I presume the answer is:  Delete the freaking line, and then recreate it the length you wanted in the first place.
The options:  Double click the line and enter a new value - conflicts with constraint.
Right click and 'edit constraints' (menu option doesn't exist, it only exists in your documentation)
Right click, show constraints.  Again, non-existant option..
I've used Corel Draw for years, and it was hard to learn, but at least you could easily change things once you got the hang of it.  I don't understand why in God green earth would someone want to lock something instantly when you create it... just makes the program ONLY usable by those of us who never make mistakes, and always create their drawings perfect the first time... and never have to modify one.
SO freaking frustrating... I got to where I was yelling at you crApp just screaming mad at it... (although, that was more when I was trying to get the stupid orbit to work.. I didn't realize you had to click ON an object to 'orbit' it.. I just wanted to change my view being 100% sure I wasn't going to change my model (so, no clicking on the model)
I suppose, eventually, the app might be usable...
davebYYPCU
Show us, with a file, pic, or screencast.  We cant say anything without seeing what you actually are complaining about.
