Why does offset surface fail!?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all, I really need some help with this, I am making a case for some electronics, I modelled the dimensions of the parts, combined them and then offset by 0.2mm. To create a larger version of the shape, this will be the internal dimension of the case, this worked fine. I have then made some changes to this body, and want to offset the surface again by 1.5mm, this will be the thickness of the case.
When I try to do the second offset, it always fails, I have had similar problems before which seem to be resolved when I individually select faces to offset as opposed to doing a marquee selection. This doesn't work, closing and reopening doesn't help either. I don't know what's wrong. Please help!
