Hi @Anonymous,
Welcome to the Fusion community and thank you for posting! Are you using any anti-virus software/firewall? If so, could you try disabling them to see if that makes any difference? It looks like Fusion is having difficulty loading the render setting window. This article may help resolve network connectivity issues.
Please let me know if you have any questions.
Hi jmk9633
Have you tried setting the Graphics Driver to DX9 via the Preferences dialog? By default this is set to auto-select between DX9 and DX11. To access launch Fusion, click the User menu then Preferences. On the General tab change the Graphics driver from auto-select to DX9.
Do the cards have multiple modes? If high performance modes are available, can you try disabling and see if it helps?
Have you tried lowering the resolution the card is using to see if this helps with the screen display?
Also, has this ever worked with Fusion and this configuration? If so, what has changed that may have affected this?
And have you checked the driver to see if it's the most current? Check the AMD site as Windows Updates don't necessarily carry the latest drivers.
Finally, if none of this works out, can you attach your log files? To create these launch Fusion, go to the Help menu (?), and click Diagnostics Log Files.
Already do all about this manual
I use display 1600X900
but I turn off my intel graphic card change 1280X800 so I don't use monitor
I send Diagnostics Log Files
how do I do?
Thanks for the logs. There's no apparent indication of any data corruption. Can you access your files by launching a web browser and going to myhub.autodesk360.com? Are they viewable, etc.?
Some things to try:
Hope this helps.
I can show myhub.autodesk360.
Don't show fusion360 but show Internet Explorer
1. I can rename NMachineSpecificOptions.xml and NGlobalOptions.xml files so I change name but data panel turn gray so they didn't work
2. but it didn't work
3. I can't use any antivirus/spyware applications
What should I do?
Thanks for your patience as we try to sort this out. We are trying to narrow this down as it doesn't appear to be an account issue. But we have to ask:
Some things to try:
Again, thanks for your patience.
I tried it, but I can't.
what should I do ??
Hmm..sounds like a phone call might help.
Can you send me a private message with a phone number, date, and time I can contact you?
