- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear forum,
I am trying to follow the third official tutorial for Fusion, "Sketch Constraints", at minute 9:03.
In it, the author draws two construction lines through the sketch of a rectangle. He mid-point-constrains both lines. As a last step, he mid-point-constrains the two lines with the origin.
In these two steps, his rectangle is repositioned.
I have attached a video of me doing the same process. Sometimes, the rectangle is repositioned, sometimes it is not. The constraints between rectangle and construction lines seem the same, no matter the order of operation. Also note that there is no coincident constraining between construction lines and rectangle (the construction lines run through the sketch).
Why do the construction lines being centered lead to the sketch being repositioned?
Thank you for any help.
Best regards
