See the attached file. I have four components. One was made by opening a 3D DXF file and using features from that to extrude. It was then copied a couple times ("Wall Left"). "Wall Right" was created by inserting another DXF and using that sketch to extrude into a body. I want to copy and move that component, but when I select the Move Tool, I can't select that component. I can select the others like I would expect. If I use the Browser to select the component, I can only move it with a pivot point in the center; I can't choose a pivot point.
I can't tell why that component behaves differently from the others. This kind of weirdness makes Fusion 360 *extremely* frustrating to use.
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
