Add curve to chamfer surface
filip.kolinsky
filip.kolinsky
Hi all, Im using F360 for longer now but always just created boxes and simple stuff and just recently started doing more complex work.
I sketched a half elipse and extruded a box out of it. Then I added chamfer (two distances, one to the very top and second 10mm to the center) so the box has a nice slope. However thats not exactly what I want. Now I want to add a bit ow a bow to the surface. if it was a flat line, I would extrude a tool, made the curve I wanted and cut it out, but as its half eclipse I dont know how to extrude such a tool. My experiments with other methods so far were unsuccessful.
How should I go about it?The boxThe boxwith chamfer and the bow I want to add to itwith chamfer and the bow I want to add to itI want it to be along this curve.I want it to be along this curve.
TrippyLighting
Can you share your model? (export as .f3d and attach to next post)
filip.kolinsky
Here it is
TrippyLighting
Here's one way to do this:
filip.kolinsky
Thank you so much! I learned so much from your short video. This is a game changer for me and I will have to experiment a bit more. Also the shortcut window is cool, didnt know there was such thing.
