Why can't I fillet this edge?
leonhamilton196
Observer Observer
leonhamilton196
Observer
Observer
Why won't it fillet this edge?
Did the same fillet on the other side already. The red edge will do it by itself but then the problem shifts to another edge no matter what order I fillet them in, 1 always has an error.
Errors:
- Failed to perform Boolean operation
- The fillet could no be created at requested size (there is absolutely enough space and usually the error fillet and the edge either side can be filleted if done in a different order.)
laughingcreek
this isn't a particularly unusual issue with bodies converted from stl files.  90% of the time the advise is to remodel stl using native fusion geometry, using the stl only as a visual reference.
there is most likely a near tangent condition between one or more of the edges.  impossible to tell with out seeing a model.  you could export it as a .f3d and attach it to the forum.
TheCADWhisperer
@leonhamilton196
This one will be easy to fix.
etfrench
I would just split it in half, then mirror the filleted side.
ETFrench
leonhamilton196
Observer
Observer
Thank you, but no need to waste your time, it worked with a 1.99 mm fillet which is accurate enough for what I need
leonhamilton196
Observer
Observer
Thanks, I'll remodel from now on, managed to get it to work with a 1.99 mm fillet which is accurate enough for me
