Help with cnc veneer cutting profile
bobRYU6U
bobRYU6U
Hi everyone,  I'm a first time poster so thanks in advance for any help you can give me. I wish to veneer a convex dome and will be the pieces on a flat vacuum bed on my CNC. My issue is that they have to fit the dome radius, but I need to cut them flat. I attach a pic of the fusion file which I hope demonstrates the issue. I just can't figure out how to do it. The dome is a 3 point arc, say 500mm diameter and 50mm height in the centre.
Warmingup1953
This will be pretty close in 36 Segments. I used an online template make to creat a 650mm Diameter (Your dimensions yielded a 650 Radius but the online generator maximum is 1000MM)
You could do it as a faceted sheet metal body I guess as well. Faceted for veneer should be within a glue line
davebYYPCU
Trace the edge with a curve / spline, for a proper job.
Unwrap in Meshmixer give the same outcome, also requires the edge traced.
Might help….
Warmingup1953
Grey is Surface Body 10 Degrees of Arc...Yellow is Meshmixwer unwrap.svg scaled 1.3333 red is my rough go via online  Template
bobRYU6U
Thank you very much to you all!  I had no knowledge of Meshmixer and only minimal understanding of Fusion. I have now trialed the process in paper and I think it works well. My thanks once more and all the best for 2024!
