who is using 123D Catch here with success?
cekuhnen
Mentor Mentor
cekuhnen
In the past 3 days I made plenty if tests and I have to say 95% turn out as garbage or fail.
Anybody has some success stories or tips? Otherwise I just will give up on this software/process as it turns out to be a majr waste of time.
I was curious to use it to roughly digitize products for TS reskinning in Fusion.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
michaelpgeyer
I've used it with some success to capture human figures (heads). It requires some finagling but produced a good result. You really need to make sure you've got even lighting, a visually simple background and take enough pictures (but not too many) to capture the entire object.
If what you're after is scanning an object for product design I suspect the resolution may not be adequate and you might want to try a 3d scanner. I don't have experience with those but have heard the makerbot version is not good. If you want advice on that pls email me and I will get you in touch with the right person. Mike.geyer@autodesk.com
Mike
cekuhnen
@michaelpgeyer We have that MakerBot scanner - don't know why they bought it because it is total junk really crap to be honest. I have a lot of experience with the next engine scanner which is pretty sufficient and well working.
the objects I might to try to digitize are too small like hand size but also bottles seem to be of an issue.
the amount of failed project is very hi which concerned. I am not sure if that is a fla in the iOS app or if t he pic desktop version is more reliable,
any idea?
Claas Kuhnen
