Pleased your pleased. Some comments in no particular order.
I was not able to constrain your sketch, not enough info, or too many guesses needed, (without the known detail you have). The blue articles in your supplied file sketch have lots of white dots (first sign of problems)
some curve overlaps (- found where the white dots are). Select a curve, the highlight shows which end point is associated.
I could rebuild a sketch, with a method I picked up in threads here along my way.
Tackle any job by breaking up into small modules.
Quick check - I found one curve set that can be offset to both sides, to supply a quick 3 track sketch.
1. Constrain as you go.
2. All constraints you can before dimensions.
3. Use flexibility when using these 2 points.
Summary of what I did,
Build and dimension away from the Origin, (arrow)
top horizontal line, is also the first radius.
Use dimensioned construction line to trim that first radius, (1) then added 3 Tangent Arcs about the right shape, dimension the arcs, then I dimensioned to the origin, point 2 in the photo., then the centre points of the intermediate curves, when locked will fully constrain those 4 curves. (3)
So the rest of the curves consisted of two sets of 3 curves that are tangent segments, 1 - 3 point curve and use Tangent Arc tool to make the next 2, then dimension them. Dimension the last end point of the 2nd set, and the centre curve's centre point.
We now have 6 black curves. So now another 3 curves, (guess 1), same method,
Due to the lack of info in the first sketch, I dimensioned the end point of the first curve of this set, and that got them to turn black. Ideally that point should not be the one carrying the dimension, but I did not get enough info to lock the 2nd curve's centre point.
With nine black curves, I then Offset the inside. 18 black curves.
Offset the outside, all black but the second point can't be a point, so fusion filleted it. Those two flat portions are a later addition.
Last thing, top neck area, (not shown), 2 lines, vertical / horizontal, and dimensioned, when adding the Tangent arc, made tangent to both ends, doesn't need a dimension.
So now there is just the two waist lines to go. (warning - do not trim the offset curves - will break the sketch)
When you get this far, you may figure it out, but will give a few clues if stuck.....
Might help...
