Where has my text command box gone
jeffescott
Advisor Advisor
jeffescott
Today for some reason the text command box  became detached for its normal location, locked below the timeline.
It started to float, i tried to move it back down below the timeline but it vanished, now I can't find it.
Also the comment box is floating but won't open.
What should I do.
I attached the file but the text command box and comment box are common in all of my designs
jhackney1972
Make sure the Show Text Commands dialog is switched on.  Close and reopen Fusion and it will be back on the screen.   Same process of the Comments Dialog box.  Also, if you are using Windows, you can use the Windows process for finding a dialog box off the screen.  A quick internet search will bring up the process.
You can also position it by dragging it until you see the green line at the position you desire.
John Hackney, Retired
jeffescott
Thank you very much.  So frustrating to loose the test command, when you cleaning up a design.
