Where do I find help on the new UIToolbar - Cant find project include...
fusion360EP98K
fusion360EP98K
I just allowed Fusion 360 to switch to the new toolbar and the first thing I want to do is project a sketch but cannot find include/project ANYWHERE!!  The help menu only gives links to the old style menu.
Is there a manual page for the new UI?
shabbir.abdulhussein
Hey,
I've attached an image of where you can find it:
It's under the sketch tab, select a plane to sketch on and click Create > Project / include
Does this help?
You can find some more useful content on the new tabbed UI by visiting the help documentation: https://help.autodesk.com/view/fusion360/ENU/?guid=Fusion_TabbedUI_quick_guide_html
You can also add any features you use frequently as shortcuts so they are easily accessible to you. See: https://help.autodesk.com/view/fusion360/ENU/?guid=Fusion_TabbedUI_shortcuts_html
Shabbir Abdulhussein
Content Designer
schneik-adsk
You need to have a sketch active.
Kevin Schneider
fusion360EP98K
Took a while before I could get back to try it.  Thanks to both of you.  I see the order is very specific.
For other newbies like me, you ust first create a new sketch or be editing an existing sketch into which you want to project another sketch.   Then in the sketch menu You will see Project/Include > Project    and I could tnen select the lines I wanted.
In my case I want to project lines from a fretboard sketch into a new Neck sketch for a guitar.
