Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
When export file to skp, file is empty
3 REPLIES 3
longhwang
153 Views, 3 Replies
I want to export files to .skp for randering, but the inside of the file is empty when I export it to .skp. It's only made with 8kb files. The same thing happens when you work on the website. Is there a solution for this?
3 REPLIES 3
CGBenner
in reply to: longhwang
@longhwang  Welcome to the forum.  Can you please share your .skp output file here so someone can take a look at it for you?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
johnsonshiue
Hi! I guess it is related to the objects in the Fusion design. Is it a brep body or a mesh or a Tspline or a sketch?
Many thanks!
Software Test Engineer
CGBenner
@longhwang Hello, do you still need help with this question?
Chris Benner
Technology Administrators
