I want to export files to .skp for randering, but the inside of the file is empty when I export it to .skp. It's only made with 8kb files. The same thing happens when you work on the website. Is there a solution for this?
@longhwang Welcome to the forum. Can you please share your .skp output file here so someone can take a look at it for you?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Hi! I guess it is related to the objects in the Fusion design. Is it a brep body or a mesh or a Tspline or a sketch?
Many thanks!
@longhwang Hello, do you still need help with this question?
Chris Benner
