It doesn't show on the pull down if you have record history enabled. Or are you using the new preview UI?
Mark
Mark Hughes
Owner, Hughes Tooling
Nope
@HughesTooling wrote:It doesn't show on the pull down if you have record history enabled. Or are you using the new preview UI?
Mark
Not using the new UI. Was it ever on the pull down, once-upon-a-time, or am I miss-remembering?
It's only ever been on the pull down menu if you're in direct edit mode. With the timeline you have to use Create Form to get access to the sculpt workspace.
Mark
Mark Hughes
